It would be nice to be able to set one to three additional goals that activate once your primary goal has been reached.
For example, say I wanted to reach a minimum of 10K steps, then stretch for 5K more and an additional 5K after that. With stretch goals enabled it would light up for the first goal, reward you with a ding, and reset for the light for the next goal to keep you motivated through the day. Plus it is easier to check the lights then to logon to the application to check my steps.
Thanks,
John
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
