You should be able to quickly add water on the front page rather than always having to click through and scroll down the page behind.
Lines and fonts are too large. The orange is more red than orange which does not mean that at a glance you can see how you are doing. It is harder to find the button to quickly access adding food as the options go over other boxes and only appear when you hover. The look and feel is way too basic compared to the old dashboard. I think much of this and other points has been said, but basically the look and feel is now very offputting.
Moderator edit: edited title to promote water tile suggestion.
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
