11-05-2020 07:54
11-05-2020 07:54
When the simulator starts to open, there will be an image. After about 30 seconds, the image will disappear and become a blank.
I can click "Force reload" in the menu bar, and then the simulator has images again. After 30 seconds, the images on the window disappear again
Best Answer11-05-2020 18:01
11-05-2020 18:01
老铁,常规操作,fitbit经常这样🤣
Best Answer11-05-2020 19:11
11-05-2020 19:11
我是在win10 x64下安装运行的,你的模拟器也是这样吗?有解决的办法吗?😥每次需要保证有25以上的电量,和需要拿出充电器,确实是够麻烦的,如果模拟器能用的话,我觉得还是模拟器比较方便些。我重新安装和删除了\AppData\Roaming\Fitbit OS Simulator 文件夹都没有作用
Best Answer11-05-2020 22:10
11-05-2020 22:10
我之前猜是fitbit服务器的问题,但是我在mac上是正常的,我同事是windows的,也出现过你说的问题,所以并不知道具体原因是啥
Best Answer01-26-2021 19:03
01-26-2021 19:03
I redo the windows system, still like this, every time I need "reload". "...
