10-15-2020 00:02
10-15-2020 00:02
I've am trying to create a clockface, but have run into a problem with the FitBit OS Simulator. When trying to change the time from 24h to 12h, the time in the simulator stays on 24h. The AM/PM label appears, but the time does not change. My code is as follows:
import clock from "clock";
import document from "document";
import { preferences } from "user-settings";
import * as util from "../common/utils";
import { goals, today } from "user-activity";
import * as fs from "fs";
import { HeartRateSensor } from "heart-rate";
import { me as appbit } from "appbit";
import { battery } from "power";
console.log((goals.steps || 0 ) + " steps");
console.log((today.local.steps || 0 ) + " steps");
// Update the clock every second
clock.granularity = "seconds";
// Get a handle on the <text> element
const hoursLabel = document.getElementById("hoursLabel");
const minutesLabel = document.getElementById("minutesLabel");
const secondsLabel = document.getElementById("secondsLabel");
const timeLabel = document.getElementById("timeLabel");
const ampmLabel = document.getElementById("ampmLabel");
const dayLabel = document.getElementById("dayLabel");
const monthLabel = document.getElementById("monthLabel");
const heartRateLabel = document.getElementById("heartRateLabel");
const batteryLabel = document.getElementById("batteryLabel");
// Update the <text> element every tick with the current time
clock.ontick = (evt) => {
batteryLabel.text = Math.floor(battery.chargeLevel) + "%";
showDate(evt);
let today = evt.date;
let hours = today.getHours();
if (preferences.clockDisplay === "12h") {
// 12h format
if(hours / 12 > 0) {
ampmLabel.text = "PM";
} else {
ampmLabel.text = "AM";
hours = hours % 12 || 12;
} else {
// 24h format
ampmLabel.text = "";
hours = util.zeroPad(hours);
let hours = util.zeroPad(today.getHours());
let mins = util.zeroPad(today.getMinutes());
let sec = util.zeroPad(today.getSeconds());
hoursLabel.text = `${hours}`;
minutesLabel.text = `${mins}`;
secondsLabel.text = `${sec}`;
timeLabel.text = `${hours}:${mins}`;
// Show Date
function showDate(evt){
let monthnum = today.getMonth();
let day = today.getDate();
let month = new Array();
month[0] = "Jan";
month[1] = "Feb";
month[2] = "Mar";
month[3] = "Apr";
month[4] = "May";
month[5] = "Jun";
month[6] = "Jul";
month[7] = "Aug";
month[8] = "Sep";
month[9] = "Oct";
month[10] = "Nov";
month[11] = "Dec";
let monthname = month[monthnum];
monthLabel.text = `${monthname}`;
dayLabel.text = `${day}`;
// Steps Counter
let steps = document.getElementById("steps");
steps.text = today.local.steps || 0;
setInterval(() => {
}, 3000 );
let arc = document.getElementById("arc-fg");
let anglePercentage = (today.local.steps || 0) / (goals.steps || 0);
let angle = 360 * anglePercentage;
arc.sweepAngle = angle;
// Heart Rate Sensor
if (HeartRateSensor) {
const hrm = new HeartRateSensor({ frequency: 1 });
hrm.addEventListener("reading", () => {
console.log(`Current heart rate: ${hrm.heartRate}`);
heartRateLabel.text = `${hrm.heartRate}`;
hrm.start();
}Am I missing something to get the time to switch from 24h to 12h? The code seems to work as the AM/PM label appears when I switch the time in the simulator.
10-15-2020 00:30
10-15-2020 00:30
You seem to be redefining 'hours' (and a few other variables). Be very careful when pasting code together.
Best Answer10-15-2020 00:48
10-15-2020 00:48
Gondwana. Thanks. You pointed me to the right direction and I've fixed the issue. As you said, I was redefinig the hours variable. That code was left in by mistake as I changed the way I wanted the time to display.
Thanks for the advice.
