When adding an activity and then selecting Log Activity, why is the 'Starts' a random time? Why can't the current time be displayed as the default start time? Also, can you add 'Treadmill' to the default activities so I don't have to use the search to be able to add it?
Best AnswerHi @Dog1cats2 Your post is on one of the developer forums. You are describing an Fitbit app issue. Do you use an Android or iPhone? Logging issues are usually seen on one platform, not both. Also, what model Fitbit do you use? All current models have an Exercise app on the device itself. Treadmill is one of the shortcuts on every current model. It is easy to track treadmill with the Exercise app.
Fitbit recommends logging with the green + button only if the activity isn’t on the Exercise app or if you forget to wear your Fitbit.
Laurie | Maryland
