Hi sspyli,
you can use getDay():
let weekday = date_var.getDay();
if(weekday === 0) {
console.log("Sun");
} else if(weekday === 1) {
console.log("Mon");
} else if(weekday === 2) {
console.log("Tue");
} else if(weekday === 3) {
console.log("Wed");
} else if(weekday === 4) {
console.log("Thu");
} else if(weekday === 5) {
console.log("Fri");
} else if(weekday === 6) {
console.log("Sat");
} else {
console.log("Err");
Best AnswerThank you SO much!
I tried to use those, but I keep getting an error message which says "date_var is not defined weekday". How would I go about doing that?
Best Answerdate_var is simply the variable name nowo chose to use to make that code snippet (it's not a special keyword, or anything) - you will need to change that to whatever you currently call your date variable.
Best AnswerThen I changed the name, shows "Expected a function", looks like still missing some code here.
Best Answerimport clock from "clock";
import document from "document";
import { preferences } from "user-settings";
import * as util from "../common/utils";
import { today } from "user-activity";
import { display } from "display";
console.log((today.local.steps || 0) + " steps");
let txtSteps = document.getElementById("txtSteps");
function update() {
steps.text = today.adjusted.steps || 0 + " steps";
// Update the clock every minute
clock.granularity = "minutes";
// Get a handle on the <text> element
const myLabel = document.getElementById("myLabel");
const myweekday = document.getElementById("myWeekday");
const myMonth = document.getElementById("myMonth");
const myDay = document.getElementById("myDay");
const txtSeps = document.getElementById("txtSteps");
// inside the clock tick handler
txtSteps.text = today.adjusted.steps || 0 + " steps";
// Update the <text> element every tick with the current time
clock.ontick = (evt) => {
let today = evt.date;
let hours = today.getHours();
let monthnum = today.getMonth();
let day = today.getDate();
var month = new Array();
month[0] = "Jan";
month[1] = "Feb";
month[2] = "Mar";
month[3] = "Apr";
month[4] = "May";
month[5] = "Jun";
month[6] = "Jul";
month[7] = "Aug";
month[8] = "Sep";
month[9] = "Oct";
month[10] = "Nov";
month[11] = "Dec";
let monthname = month[monthnum];
let weekday = date1.getDay();
if(weekday === 0) {
console.log("Sun");
console.log("Mon");
console.log("Tue");
console.log("Wed");
console.log("Thu");
console.log("Fri");
console.log("Sat");
} else {
console.log("Err");
display.onchange = function() {
if (display.on) {
console.log("ON");
updateSteps();
if (preferences.clockDisplay === "12h") {
// 12h format
hours = hours % 12 || 12;
} else {
// 24h format
hours = util.zeroPad(hours);
let mins = util.zeroPad(today.getMinutes());
myLabel.text = `${hours}:${mins}`;
myMonth.text = `${monthname}`;
myDay.text = `${day}`;
myWeekday.text = `${weekday}`;
Best AnswerUse the same setup as you use already for your month name.
Replace
if(weekday === 0) {
console.log("Sun");
console.log("Mon");
console.log("Tue");
console.log("Wed");
console.log("Thu");
console.log("Fri");
console.log("Sat");
} else {
console.log("Err");
with
var day = new Array();
day[0] = "Mon";
day[1] = "Tue";
day[2] = "Wed";
day[3] = "Thu";
day[4] = "Fri";
day[5] = "Sat";
day[6] = "Sun";
let dayname = day[today.getDate];
then
becomes
myWeekday.text = `${dayname}`;
Best AnswerEDIT: Ignore. See my suggested fix above.
Best AnswerI've edited my answer above. Now that I can see your code, it's easier to replicate the monthname setup you're already using.
In your code above, you don't actually set a name for the day - you're logging the name to the console, but never actually retaining the name, so at best your weekday.text would be "0", "1", ... "6". In my code above, the name is actually set and used.
Note that for me the first day of the week is Monday, so I used that for value 0... If your week starts with Sunday, use that for value 0 (as nowo did in their example).
Best AnswerCheck your code:
^ note not a capitol W
but later on you call it with a capitol:
I suspect that's all you're seeing just now.
Best AnswerThank you for that. Then I replaced the "const weekday" to "const Weekday". Then another issue came up, Unhandled TypeError, "can't set property "text"of null my Weekday.at the final line. And also did you see the clock face, all the weekday came out.
Best AnswerThis is from the original Fitbit sample. It has been working for me...
//Get the date in the proper order
function formatDate(date) { var monthNames = [ "Jan", "Feb", "Mar", "April", "May", "June", "July", "Aug", "Sep", "Oct", "Nov", "Dec" ]; var dayNames = [ "Sun", "Mon", "Tues", "Weds", "Thurs", "Fri", "Sat" ]; var day = date.getDate(); var monthIndex = date.getMonth(); var year = date.getFullYear(); var todayIndex = date.getDay(); return dayNames[todayIndex] + ', ' + day + ' ' + monthNames[monthIndex]; }
Best AnswerSo I used the code you sent, then my clockface shows like this. Is there any thing I missed?
