03-14-2021 04:48
03-14-2021 04:48
In building my first AOD clock face, it would be great to have an example to work/learn from.
Can any of you point me to a AOD source? Thanks in advance!
03-14-2021 12:40
03-14-2021 12:40
Probably the closest thing would be the code snippets in the announcement blog post.
There may not be much more, because AOD submissions aren't yet open to everyone, and AOD products can't be installed on watches prior to submission and approval. But you can develop and test on simulator.
03-14-2021 12:40
03-14-2021 12:40
04-22-2021 02:33
04-22-2021 02:33
I try to implement an aod clockface to collect some experience with the simulator. But even with the simulator I'm not allowed to run such clockfaces - I thought I read a comment which said that in the simulator everybody is able to test aod clockfaces? But obviously it's not the case...
Best regards
Capitano
04-22-2021 02:57
04-22-2021 02:57
I don't know if you can do this (easily) in Studio, but you need to request access_aod in package.json.
04-22-2021 05:23
04-22-2021 05:23
Thanks, once again!
Yes I can add this permission manually by renaming the package.json file
Best regards
Capitano
