06-25-2018
05:26
07:31
JonFitbit
06-25-2018
05:26
07:31
JonFitbit
Let's say I want to be able to programmatically animate the fill color of an image using any of the following transitions:
Setting up any one of those transitions is straightforward:
<svg>
<defs>
<symbol id="image-symbol"> <image href="images/image.png" /> <animate id="animate" begin="enable" attributeName="fill" from="#ff0000" to="#00ff00" dur="0.25" /> </symbol>
</defs>
<use id="image" href="#image-symbol" />
</svg>
However, in order to accommodate all of those transitions, I would ideally be able to set the from and to attributes dynamically in JavaScript. I was hoping to be able to do that in the following way:
let image = document.getElementById("image");
let animate = image.getElementById("animate");
animate.from = "#ff0000";
animate.to = "#0000ff";
However, this doesn't work. Is there any way to access these from and to attributes?
Best AnswerAfter experimenting a bit I couldn't either find these properties, however I found that one way to get more programmatic control would be to define the the animations you want in SVG and call them using the animate(event) method.
<svg>
<defs>
<circle cx="50%" cy="50%" r="80" fill="#ffffff">
<animate id="toRed" begin="enable" attributeName="fill" from="#ffffff" to="#ff0000" dur="1" />
<animate id="toGreen" begin="enable" attributeName="fill" from="#ffffff" to="#00ff00" dur="1" />
<animate id="toBlue" begin="enable" attributeName="fill" from="#ffffff" to="#0000ff" dur="1" />
</circle>
</symbol>
</defs>
</svg>With this javascript
import document from "document";
const toRed = document.getElementById("toRed");
const toGreen = document.getElementById("toGreen");
const toBlue = document.getElementById("toBlue");
// Animate one of the elements animation properties.
toRed.animate("enable");
// Randomly alternate between 3 animations.
const animations = [toRed, toGreen, toBlue];
setInterval(function() {
animations[Math.floor(Math.random()*2)].animate("enable");
}, 2000);Here I just set up a simple random color changer (on a circle in the example) but it should work with click events or other kinds of interaction. I know it doesn't answer the question about setting from and to attributes but it might be a way for you to define and control several transitions on the same element.
