Hi everybody,
Is is possible to do a property animation of an UI element that is triggered by the watch moving from blank screen / show any menu to "show the clockface", ie. user sits there with black screen, moves wrist to look at watch, clockface appears and element animates from transparent to opaque. Activate/load/enable all don't seem to do the job...
Thanks!
Karlheinz
display.onchange = () => {
if (display.on) {
startAnimation();
}This should work in your case.
Best AnswerThanks, that did it!
So in more details I did the following (feel free to correct me if my conclusions are just coincidences)
Defined my "use" element in index.gui as the Animations Guide says:
<defs>
<symbol id="stairrect">
<rect id="stairs" x="5" y="0" width="44" height="100%" fill="grey" pointer-events="visible">
<animate attributeName="opacity" begin="click" from="1" to="0" dur="0.3" final="keep" />
<animate attributeName="opacity" begin="click+0.3" from="0" to="1" dur="0.3" final="keep" />
</rect>
</symbol>
</defs>
And later:
<use id="stairsuse" href="#stairrect" width="44" height="100%" />
Then in Javascript:
import { display } from "display";
... your code to trigger the animation on the display.onchange event ...
function startAnimation() {
stairsUse.animate("click");
It seems that the event to use (here: "click") can be anything; it just has to be consistent in index.gui and index.js, ie no matter what trigger I define in the JSON, that's the trigger to use for Javascript animation.
