10-29-2019 06:36
10-29-2019 06:36
We're proud to announce the latest version of the software development kit for Fitbit OS. SDK 4.0 adds support for the new Fitbit Versa 2, a comprehensive update to the Cryptography API, multi-view SVG support, and much more.
https://dev.fitbit.com/blog/2019-10-29-announcing-fitbit-os-sdk-4.0/
10-29-2019 09:38
10-29-2019 09:38
In addition to the API changes, there has also been a complete rewrite of the communication stack on device and mobile. This new stack provides improved reliability & performance, true multiplexing, and Quality of Service (QoS).
Nice. I suppose it's all out of the box and automatic. I couldn't find any changes in the reference doc for the Messaging API.
Best Answer10-29-2019 10:04
10-29-2019 10:04
Correct. It's automatically selected when you use Fitbit OS 4.0.x, and no API changes.
10-29-2019 13:02
10-29-2019 13:02
This is fantastic! Thank you, Thank you, Thank you!!! 😁
Best Answer10-29-2019 20:11
10-29-2019 20:11
Hello @JonFitbit
I like the new SDK, but the changes in listDirSync and brightnessOverride broke part of my watchface, including the part that makes it a watch.
I have a fix that addresses these issues in for Fitbit review, but that takes several days and I'm losing users now.
Is there any way to expedite the process?
Watchface is ILuvChrono
https://gallery.fitbit.com/details/bda6f514-3946-49ba-a4ed-75e8470ab034
Best Answer10-30-2019 03:00
10-30-2019 03:00
I'm curious to know how these changes you mentioned broke your clock. Not aware of any issues with listDirSync outside of the simulator (the bug isn't present on real watches). The changes to brightnessOverride should be backwards compatible. What issues are you seeing exactly?
Best Answer10-30-2019 05:49
10-30-2019 05:49
Best Answer10-30-2019 05:54
10-30-2019 05:54
So the listdir issue is just in the simulator, we'll fix that in the next update, hopefully quite soon. It won't affect real users.
The brightness setting issue it sounds like you might be seeing after updating your app to SDK 4.0, but existing users in the field using a version built against SDK 3.0 or 3.1 won't see that. It's only when you specifically build against the new version that these breaking changes apply to you.
We have a summary of the breaking changes to beware of when upgrading SDKs here: https://dev.fitbit.com/build/guides/migration/
Best Answer10-30-2019 12:53
10-30-2019 12:53
10-31-2019 16:12
10-31-2019 16:12
Got the same thing with mine. It appears that all gradient rectangles are not being shown.
Best Answer10-31-2019 17:40
10-31-2019 17:40
Hello @gaperton , @LiamFitbit ,
I have my Beta test Versa and Ionic working now. While I don't know the underlying problem (I no longer think it was the listDirSync), the watchface looks as it would look if the iniitialization did not complete.
When I used a beta version UUID for the ILuvChrono watchface, The Fitbit app would not let me load ILuvChronoBT and was prompting for a companion and device update.
After I updated the Fitbit app from Google play, the device profile showed the red update needed ribbon/button. After I completed the device update the watchface started as it should, with a complete initialization, and a fully functional watchface. When I restarted the companion app everything started communicating cleanly and all is well now.
After the updates I was able to install the beta version, but to be clear, the watch was already working at that point and had been since the updates completed.
Also,... My Beta test Ionic has been functional since the update and I don't know what you did to the comms et al, but it burns far less power than it did before the update, and it was a power sipper to start with. Excellent job! I really do appreciate the result.
Thank you and Regards,
Reign
Best Answer10-31-2019 21:15
10-31-2019 21:15
I'd like to chime in on that and say that I've also noticed my clockfaces compiled with SDK4 seems to drain the battery about 1%/hr. Previously it was around 2.5%/hr. So that's nice.
11-05-2019 10:36
11-05-2019 10:36
Is there some detailed changelog for the Fitbit App?
All I can find for every update is "Bug fixes and performance improvements", which might be true obviously, but not very useful for watch app developers.
Best Answer12-07-2019 18:49 - edited 12-07-2019 18:50
Fitbit studio is still showing 4.0 as the latest version for me - is this correct, or should there be a minor update?
I thought I read somewhere that there was a minor update to correct problems on Versa Lite. I am currently updating all me watch-faces to 4.0, and some have already been accepted. Will they be OK for Versa Lite users? (I don't have a versa Lite to test, other than the simulator).
Best Answer12-08-2019 03:20
12-08-2019 03:20
Studio only shows the major and minor components of the version, since being hosted-service it always uses the latest patch version for you. Currently at time of writing Studio uses SDK version 4.0.1 when you target the 4.0 SDK, so as long as you built your 4.0 clocks within the last month or so, they'll have the fix.
The fixes we made in 4.0.1 only affected usage of the activity history API on Versa Lite though, so if you weren't using that, any issue you were seeing is something separate not addressed by that patch.
12-08-2019 11:30
12-08-2019 11:30
Great - thanks!
Best Answer02-01-2020 08:21
02-01-2020 08:21
I have the note 9 and I can not read my text messages on my phone. How can that be fixed?
Best Answer02-01-2020 08:22
02-01-2020 08:22
Sorry I ment on the fitbit
