Good morning Fitbit dev community. I have been looking through the documentation and can not find any examples of arcing text ( around a circle). I know this is possible. Could someone please point me in the right direction.
Thank in advance.
Oh, I still can not get the ionic simulator to install an app, the versa one is fine, the Ionic one continues to fail.
I found this
https://gist.github.com/jebeck/196406a3486985d2b92e
Not sure how it works, I might give it a try
Oh, of course, you can. Put your text inside of <g> tag's, then select g tag by id and rotate it. Or, just inline the transformation, like <g transform="rotate(30)">. If you need the long sentence to be drawn around an arc though, you might find yourself rotating every single letter.
These g transformations are the strongest part of the Fitbit SDK. You can do incredible things if you use it smartly.
