10-11-2017 07:26
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
10-11-2017 07:26
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
I am starting to work on creating my watch face. I am not a developer, just playing around a bit with some coding knowledge.
Here is what I coded. I would like to know the opinion of more experienced developers if this is a good starting point for building on it. Also I am going to test battery drainage, I had some issues before adding the display event.
import clock from "clock";
import { display } from "display";
import document from "document";
import * as util from "../common/utils";
// Update the clock every minute
clock.granularity = "minutes";
let myDate = document.getElementById("myDate");
let myTime = document.getElementById("myTime");
display.addEventListener('change', function() {
if(display.on) {
updateClock();
function updateClock(){
clock.ontick = function(evt) {
myDate.innerText = (evt.date.toString().slice(0,10));
myTime.innerText = ("0" + evt.date.getHours()).slice(-2) + ":" +
("0" + evt.date.getMinutes()).slice(-2);
} else {
// nothing happens after this
Accepted Solutions
10-12-2017 03:17
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
10-12-2017 03:17
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
A few points:
You don't need to use the `change` event, the `tick` event only fires when the screen is on anyway.
You shouldn't nest your functions inside the events. Declare them once, then make calls to them from within the events.
10-12-2017 03:17
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
10-12-2017 03:17
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
A few points:
10-12-2017 05:17
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
10-12-2017 05:17
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Thanks @JonFitbit !
I'll change and see if the battery drainage from the other post doesn't happen. So far it was working well.
