I am attempting to use the sample code given for the button settings in the documentation.
In Setttings - index.jsx I have the import statement for settingsStrorage and the code for the button:
<Button
list
label="Clear All Settings"
onClick={() => this.props.settingsStorage.clear()}
However - when I execute I get in the consolelog TypeError: undefined is not an object (evaluating '_this.props')
I am able to use settingsStorage.clear() in the companion index.js.
I am sure I am missing something obvious but it is Monday...
You shouldn't need to import anything, but props needs to be in the function signature.
Try something like this:
function mySettings(props) {
return (
<Page>
<Section
title={<Text bold align="center">Settings</Text>}>
<Button
list
onClick={() => props.settingsStorage.clear()}
</Section>
</Page>
registerSettingsPage(mySettings);
[EDITED]
It looks like you're mixing the Settings API (jsx) with the Companion API (js).
Remove the first 2 import lines, and confirm that this file is settings/index.jsx
Best AnswerI have confirmed that I am working within the index.jsx file. Taking out the two import lines did not help. I am still getting the same TypeError:
I also started a new settings project and put a simple textInput in with the above code and got the same error in there as well.
Best AnswerIn settings/index.jsx, this works for me:
<Button
label="Create/Update"
onClick={() => {
props.settingsStorage.setItem('createAccount', 'true');
/>No 'import' statements or 'this' are required (or allowed).
