02-03-2022 18:10
02-03-2022 18:10
Has anyone using the tools FitBit has available to calculate an immediate HRV. Not a day's average or something like that but given 10--15 seconds of Heart Rate data being able to get a reliable calculation for what the users HRV is doing. I am aware that the FitBit does not allow access at least yet to the HRV information, so has anyone had any luck calculating this themselves? Thank you in advance!
02-08-2022 01:20
02-08-2022 01:20
Looks like you can sample the heart rate directly on the app: https://dev.fitbit.com/build/reference/device-api/heart-rate/
I couldn't see a way to extract this data from the Web API. If that's what you're looking for, maybe check if the Feature Suggestions board has already got a similar suggestion to upvote, otherwise you can raise a new one.
https://community.fitbit.com/t5/Feature-Suggestions/idb-p/features
Hope this helps!
Best Answer02-08-2022 01:20
02-08-2022 01:20
Hope this helps!
