01-11-2022 02:08
01-11-2022 02:08
I use a fitbit versa 3.
I want to extract some data via python.
I have accessed the data including web API ex. heart rate, steps.
Next, I want to extract raw acceleration data, which include device API.
How do I enter the python code?
01-12-2022 21:27
01-12-2022 21:27
Start here. It may not look like you're using the Device API, but `document` is an object in the Device API. Browse the Guides and Reference sections.
01-12-2022 21:11
01-12-2022 21:11
You can access accelerometer data, but you'll need to use JavaScript. That's the only language that can run on the watch, and therefore use the Device API.
01-12-2022 21:23
01-12-2022 21:23
Thank you Peter
I will try it.
Could you introduce me the sample or web site described how to access the Device API using JavaScript?
01-12-2022 21:27
01-12-2022 21:27
