08-27-2022 10:02
08-27-2022 10:02
Hi!
I can't set any setting from index.js
All of those give the error "TypeError: Cannot create property 'code' on boolean 'true'"
settingsStorage.setItem("time", JSON.stringify( {selected:[0],values:[{"name": "12hs"}]} ));
settingsStorage.setItem("lang", JSON.stringify( {"selected":[0],"values":[{"name":"English"}]} ));
settingsStorage.setItem("zpad", "false");
settingsStorage.setItem("eightBg", "false");
settingsStorage.setItem("alpha", JSON.stringify(0.05));
settingsStorage.setItem("style", JSON.stringify( {"selected":[0],"values":[{"name":"Suunto", "value":0}]} ));
settingsStorage.setItem("dataFont", JSON.stringify( {"selected":[0],"values":[{"name":"Roboto"}]} ));
HELP! 😞
Best Answer08-28-2022 13:31
08-28-2022 13:31
That's right. The Settings interface is only in the Companion API. It's up to you to communicate relevant settings to the watch. I recommend file transfer. There are some prefab solutions and examples in Fitbit's OSS github repo.
Best Answer08-27-2022 14:19
08-27-2022 14:19
Superficially, that looks okay to me. Is this definitely in your companion/index.js?
Is the import correct? Could you be accidentally changing the imported binding somewhere?
Best Answer08-28-2022 08:55
08-28-2022 08:55
App cannot reach settings even if I imported it right? Settings only can be accesed into companion?
08-28-2022 13:31
