Certificates for internal fitbit sites have an issue. Perhaps they expired? I didn't dig hard enough to see if it was the Lets Encrypt issues from earlier this month. Once I discovered that https websocket connections were failing, I lost interest in chasing the problem further.
This is causing problems connecting to the developer portal, along with issues with connecting to Pandora
https://https://035-v3-client.fitbit.com/
Someone could be trying to impersonate the site and you should not continue.
Websites prove their identity via certificates. Firefox does not trust 035-v3-client.fitbit.com because its certificate issuer is unknown, the certificate is self-signed, or the server is not sending the correct intermediate certificates.
Error code: SEC_ERROR_UNKNOWN_ISSUER
View Certificate
That domain in theory is a non-public one using our own root CA. I don't think that is related to your specific issue.
Best AnswerThanks, that makes sense.
The confusing part is that I've got both a Versa 2 and a Versa. The Versa 2 is new, and I cannot get it to connect to the developer portal without throwing the "Connection error 1006". I switched back to the Versa, and it can still connect to the portal just fine.
I can see that it is connecting to that 035-v3-client.fitbit.com host briefly multiple times before it throws the 1006 error.
