Hi guys,
I am trying to change views in the new SDK 5.0 using pointer-events when I tap the screen.
I have 2 views:
1. index.view
2. custom1.view
I get the error 'Cannot set property 'onclick' of null'.
My code is as follows:
My index.view is:
<!-- index.view -->
<svg>
<rect id="background0" height="100%" width="100%" pointer-events="visible" class="background" />
<text id="screen1Text" x="50%" y="80%" pointer-events="visible">This is screen1</text>
</svg>
The custom view is:
<!-- custom1.view -->
<svg>
<animate attributeName="x" from="100%" to="0" begin="load" dur="0.5" easing="ease-in-out" />
<svg>
<rect id="background1" height = "100%" width="100%" pointer-events="visible" />
<!-- your content goes here -->
<text id="screen2Text" x="50%" y="80%" pointer-events="visible">This is screen2</text>
</svg>
</svg>
And the index.js is:
var flag = 1;
const background0 = document.getElementById("background0");
const background1 = document.getElementById("background1");
/* Update - screen*/
function updateScreen(){
console.log(`The flag is ${flag}` )
if(flag == 1){
console.log("I am in index.view, moving to custom.view")
flag = 2;
console.log(`The flag is ${flag}` );
document.location.assign('custom1.view');
else{
console.log("I am in custom.view, moving to index.view")
flag = 1;
document.location.assign('index.view');
background0.onclick = function() {
updateScreen();
background1.onclick = function() {
updateScreen();
You didn't mention which click is failing, so I assume it's background1.
Try adding the `click` event after the view is loaded.
document.location.assign('custom1.view').then(() => {
background1.addEventListener("click", () => {
console.log("background1 click");
Best AnswerHi Jon,
Yes it is background1 (from custom1.view) that does not click. That is helpful!
I modified what you suggested and called the getElementByID and then the onclick function, and it seems to be working as per the below. It looks like I also have to do the same thing to return to the initial screen 'index.view.'
Thanks.
Assign custom1.view
const background1 = document.getElementById("background1"); background1.onclick = function() { updateScreen(); }
Assign index.view
document.location.assign('index.view').then(() => {
const background0 = document.getElementById("background0"); background0.onclick = function() { updateScreen(); }
