04-25-2018 07:52
04-25-2018 07:52
Hi folks,
i'm looking through the docs, but can't find any reference on how to change the checkbox color in a tile.
In this section the check box item is mentioned: https://dev.fitbit.com/guides/design-guidelines/ui-components/#checkbox-tile, but how can i set the color?
Is there something similar for checkboxes like for square buttons?
<use id="mybutton" href="#square-button" y="5" fill="fb-red"> <set href="#text" attributeName="text-buffer" to="Click Me!" /> </use>
Thanks in advance,
Florian
Best Answer04-25-2018 09:53
04-25-2018 09:53
You can do it in CSS:
.checkbox-tile-image image { fill: fb-cyan }
.checkbox-unselected-color image { fill: fb-red }
04-25-2018 09:53
Best Answer04-25-2018 10:04
04-25-2018 10:04
Thanks Jon, works like a charme!
Best Answer04-26-2018 00:52
04-26-2018 00:52
@JonFitbit One remaining question thematically related to tiles... (don't want to open an extra thread)
I get some strange behavior when hiding tiles from a VirtualTileList component. When i hide
tiles via it's click callback (f.e. in the middle of the list), some tiles (at a shifted position in the list)
are also hidden. I assume that i'm doing something wrong with the list's redraw method or the alignment.
this.list = document.getElementById("my-list");
var NUM_ELEMS = 30;
var SATURATION = (Math.random() % 0.5) + 0.5;
var VALUE = (Math.random() % 0.5) + 0.5;
var HUE_CONST = 1.0 / NUM_ELEMS;
var STARTING_POINT = Math.random() * NUM_ELEMS;
var STARTING_POINT = 0;
let tileState = {}
this.list.delegate = {
getTileInfo : function(index) {
var tile_type = "colour-pool";
return {
type : tile_type,
color : that.HSVtoRGB(HUE_CONST * ((index + STARTING_POINT) % NUM_ELEMS), SATURATION, VALUE),
index : index
configureTile : function(tile, info) {
tile.getElementById('bg').style.fill = info.color;
tile.getElementById('title-text').text = "Part #" + info.index;
tile.info = info;
tileState[info.index] = tile.getElementsByClassName("tile-item-checkbox")[0].value;
tile.getElementsByClassName("tile-item-checkbox")[0].onclick = (evt) => {
tileState[info.index] = !tileState[info.index];
vibration.start("bump");
tile.hide();
//tile.align({alignment: 'bottom', animate: true, redraw: true});
that.list.redraw(true);
Thanks in advance
Best Answer04-26-2018 09:04
04-26-2018 09:04
I found this note:
// KNOWN ISSUE: It is currently required that VTList.length be set AFTER VTList.delegate VTList.length = NUM_ELEMS;
Best Answer04-27-2018 02:32
04-27-2018 02:32
Nope... no effect. I already had this in my code. But when hiding a tile from its list (not deleting), it shouldn't effect the list length?! Even if i adapt the length after hiding a tile, the effect occurs ![]()
Do you have some details about the insertTile and obtainTile methods? Unfortunately i can't apply these methods on the TileList.
Best Answer04-29-2018 12:58
04-29-2018 12:58
No hint, how to move on? 😬
Best Answer05-01-2018 00:19
05-01-2018 00:19
I investigated the reason for the odd behavior. The virtual tiles are all instantiated from the predefined tile pool. You can add more tiles via JavaScript, but all visible tiles share the id attribute from the tile pool. Thats why f.e. if hiding a tile at position 0, also the tile at n+tile-pool-length is hidden. Thats logical but also rediculous because there is no chance to apply data binded actions on virtual tiles, as there is no chance to explicit identify them.
Best Answer05-01-2018 02:38
05-01-2018 02:38
I had a chat with some people internally about this.
The correct way to "hide" an item in a virtual tile list is to do so in the draw callback, by drawing item N+1 instead of item N. Virtual Tile List does not keep track of hidden / deleted for you,
Best Answer11-04-2020 16:27
11-04-2020 16:27
Hello, I am trying to use the checkbox component in an SDK 5.0 application. Can you give me a link to the documentation for this component, if it exists for SDK 5?
