01-26-2020 04:40
01-26-2020 04:40
I made an app on my Fitbit Versa 2 where I can control my garage door. It fetches an URL on my raspberry which triggers the garage. Sometimes nothing happens as the companion app is not running due to synchronisation errors (on the same time alexa is not working on my watch either).
Is there any way to test if the companion app is running and displaying the status? So I know if I have to get out my keys for the garage instead of the app.
Best Answer01-27-2020 13:42
01-27-2020 13:42
It sounds like the Fitbit mobile app is being killed due to battery optimization on your phone. Check your phone settings.
Best Answer08-02-2021 17:02
08-02-2021 17:02
But how can we check if the companion is active, Messaging API still reads the socket as open even though messages sent aren't received by the companion in 4.3.0
08-02-2021 17:16
08-02-2021 17:16
Put code in the companion to reply to messages. In your device, ensure that replies are received within a reasonable period of time.
Best Answer08-02-2021 19:08
08-02-2021 19:08
Sounds good, however is there an event that knows when the companion becomes active from inactive? I just don't want to drain battery with message callbacks, and timely inform the user when the device is connected with the companion
Best Answer08-02-2021 19:38
08-02-2021 19:38
You could try onclose and maybe onerror.
Best Answer08-03-2021 00:44
08-03-2021 00:44
Is there one for when the companion becomes active?
Best Answer08-03-2021 10:18 - edited 08-03-2021 10:28
This may not be exactly what you are looking for, but here's what I do to talk to my companion:
import { peerSocket } from "messaging";
const err_element = document.getElementById("err_element");
//send message to companion
function sendMessage() {
if (peerSocket.readyState === peerSocket.OPEN) {
// Send to the companion
peerSocket.send("Whatever I want");
else {
console.log("CONNECTION CLOSED");
err_element.style.display = "inline";
err_element.style.fill = "red";
// Listen for messages from the companion
peerSocket.onmessage = function(evt) {
console.log(evt);
// Listen for the onopen event
peerSocket.addEventListener("open", (evt) => {
// console.log("Ready to send or receive messages");
// Listen for the onerror event
peerSocket.addEventListener("error", (err) => {
console.log("Connection error: " + err.code + " - " + err.message);
Maybe you can rig something up that'll send a message every X seconds/mins or something to check connection, then if it fails, set an icon on your fitbit to a different color (which is what I do)
Best Answer08-03-2021 14:53
08-03-2021 14:53
That is a viable choice, however the problem is that if the user turned on their phone and their phone becomes active, it may take a few minutes.
Another consideration is that how frequent it checks also impacts battery.
I'm currently using Appbit API for the unload event, but where is the event when the companion becomes active is my question.
Best Answer08-03-2021 15:23 - edited 08-03-2021 15:24
In its startup code, you could get the companion to send a message to the watch.
However, the companion will only start when it needs to; eg, receiving a message or file, user starts settings, or wake interval.
Best Answer08-03-2021 15:54
08-03-2021 15:54
Ooh okay, sounds interesting
Will find out later today
Best Answer08-04-2021 15:47
08-04-2021 15:47
You maybe could also use the launchReasons to detect why the companion has launched. Companion Guide (fitbit.com)
Best Answer08-15-2021 03:43 - edited 08-15-2021 03:49
dismiss reply will try later
