05-24-2019 06:00
05-24-2019 06:00
I have a TileList with checkbox-tile's and using code similar to the code below to determine if a box is selected or not. I can reference each checkbox by tileState[0], tileState[1], tileState[n], so it seems to mean the tileState is an array. However, if I try tileState.length, I get an error. So, I'm not sure if tileState is an array or not. Is there a way to loop through the tileState like you would an array?
let tileState = {} tileItems.forEach((element, index) => { tileState[index] = element.firstChild.value; // initial state element.firstChild.onclick = (evt) => { tileState[index] = !tileState[index]; console.log(`item ${index} :: ${tileState[index] ? "checked" : "unchecked"}`) }; });
05-29-2019 11:05
05-29-2019 11:05
I declared the tileState as an array and that fixed the issue. I took the code from the manual and didn't know if there was a reason why the manual declares the tileState as an object.
05-28-2019 11:10
05-28-2019 11:10
Can you provide a bit more code? You've declared tileState as an object in the example. Thanks
05-28-2019 11:29
05-28-2019 11:29
This code came from the View Components Guide. I noticed tileState was declared as an object and not an array. I wasn't sure if there was a reason for doing it that way.
05-29-2019 11:05
05-29-2019 11:05
