I know customize font is not supported now, and I found there is only ONE Chinese font there, unfortunately with a lot of characters missing.
(see demo pictures for detail that's 钵 讫 耨)
Do you have any recommendation on fixing the default Chinese font?
Can developer patching font within their app in some way?
Thank you!
Best Answerthese characters cannot be displayed under Simplified Chinese:
钵 讫 耨 谛 诃 涅 偈 洹 诤 ;嗔 诳
for Simplified Chinese
@dragonBTV wrote:these characters cannot be displayed under Simplified Chinese:
Is this the Ionic? Does it display most Chinese characters (simplified and traditional)? Thanks!
Best AnswerIs this the Ionic? Does it display most Chinese characters (simplified and traditional)? Thanks!
Best AnswerI just tried above Chinese characters,yes, Ionic doesn't support these characters, I also changed the language on my phone, it seems that ionic doesn't support traditional Chinese right now ,only support simplified Chinese, we expect Fitbit will add that in further firmware updates
