06-14-2018 11:35
06-14-2018 11:35
In my settings index.jsx file I have a toggle that when it is set to true, it enables a select setting in which the user can then select up to 3 items. What I need to do i when the toggle is set to false, to not only disable the select setting, but clear any items that may have been selected. I am trying to use prop.settingsStorage.removeItem. Here is my code. Any help is appreciated.
<Toggle
settingsKey="toggle"
label="This is a Toggle"
onchange={() => props.settingsStorage.removeItem(selector)}
<Select
label={`MultiSelector:`}
multiple
settingsKey="selector"
options={[
{name:"item1"},
{name:"item2"},
{name:"item3"},
disabled={!(props.settings.toggle === "true")}
Best Answer06-30-2018 07:11
06-30-2018 07:11
removeItem expects a string of the key.
onchange={() => props.settingsStorage.removeItem("selector")}
