Hello dev world, is it possible to change the background PNG of a watchface by just clicking the screen? eg, if I had a background image and just wanted to change to another with a click of the screen, can it be done?
Thank you in advance
Best Answerindex.js
import document from "document";
var img = document.getElementById("myImage");
img.href = "1.jpg";
img.onclick = (e) => {
console.log("clicked");
if (img.href === "2.jpg") {
img.href = "1.jpg";
} else {
img.href = "2.jpg";
console.log("App Started");
index.gui
<svg> <image id="myImage" x="0" y="0" width="100%" height="100%" href="./1.jpg" pointer-events="visible" /> </svg>
wrote:index.js
import document from "document"; var img = document.getElementById("myImage"); img.href = "1.jpg"; img.onclick = (e) => { console.log("clicked"); if (img.href === "2.jpg") { img.href = "1.jpg"; } else { img.href = "2.jpg"; } } console.log("App Started");index.gui
This. But just as a friendly reminder, the key thing here for allowing onclick handlers is to add the pointer-events attribute to the element you want clickable.
