05-11-2018 23:51
05-11-2018 23:51
Hi all,
I'm working within the versa simulator - but I can't get my combo button to trigger.
I've put in a console log for when it works and so far nothing.
How do I configure this to work?
In my widgets.gui I have:
<svg>
<defs>
<link rel="stylesheet" href="styles.css" />
<link rel="import" href="/mnt/sysassets/widgets_common.gui" />
<link rel="import" href="/mnt/sysassets/widgets/square_button_widget.gui" />
<link rel="import" href="/mnt/sysassets/widgets/combo_button_widget.gui" />
</defs>
</svg>In my index.gui I have
<use id="h-btn-br" href="#combo-button-lower-right" fill="fb-green">
<set href="combo-button-icon" attributeName="href" to="sync.png"/>
<set href="combo-button-icon-press" attributeName="href" to="sync_press.png"/>
<set href="combo-button-stroke" attributeName="display" to="inline"/>
</use>and in my index.js I have
import document from "document";
let refreshBtn = document.getElementById("h-btn-br"); refreshBtn.onactivate = function(evt) { console.log("works!"); //refreshData(); }
One thing I should note - my custom icons for the combo button don't appear - so I can see the stroke of the button, and when I click it the fill colour changes - but I can't see any icon. Would that be causing any errors?
Thanks for any help
Best Answer05-12-2018 01:20
05-12-2018 01:20
I've found a work around in where I just use a different type of button for now.
05-12-2018 01:20
