Hi.
I am having problems with the Companion app not starting. Using the BART example (also tried another app that is working for others) the companion app does not start. There are no console messages from companion/index.js in Fitbit Studio or on the Fitbit Android App – Sideloaded Apps. Here the logs are empty and Status is Unavailable. If I try to Delete Application from Sideloaded Apps I get ‘Failed to delete app’. Developer Bridge is enabled and connected on the Ionic and the Android app.
I have tried, along with many restarts of the phone and the Ionic:
This did not help.
I performed a Factory Reset on the Ionic along with 1 and 2 above and this temporarily resolved the issue, the BART companion app did start. However when I make any change to the Sideloaded app and redeploy, or add another Sideloaded app the issue reoccurs and the previously working companion app will never start again. The Factory reset is taking around 30 mins so this is not really a usable workaround.
Any ideas?
Thanks Lee
Ionic: 27.30.3.2
Fitbit (Android): 2.60 (2193190)
Android: 7.0 (Galaxy S8)
I encounter something similar. Sometimes, after sideloading a clockface of mine, the companion does not start. Sometimes a sync solves it but often I need to re-sideload it and then it does work. And keeps on working. Until I use the Music app which kills the traffic between the app and the companion. Not tried a workout app yet. Will try this evening.
Best AnswerI face the same issue. When I start the application on my fitbit ionic connected to my Galaxy S8, the companion code is not started. The only way to fix this is to open the settings and change at least one.
That's quite impacting for many scenario as without the companion started i can not make any fetch from the internet.
