I am having some issues in communicating with the companion. It seems to start only once in a while.
My starting code is the same as of a new project from studio with file transfer.
Companion starts only once in a while. Also timestamp seems to be completely off. Please see below.
Is there a basic launch code to insert in the app/index.js so that it goes straight to start companion code?
My code in the app:
import document from "document";
import { inbox } from "file-transfer";
import fs from "fs";
// console.log("App Started");
let statusText = document.getElementById("status");
statusText.innerText = "Waiting...";
// Event occurs when new file(s) are received
inbox.onnewfile = () => {
console.log("New file!");
let fileName;
do {
// If there is a file, move it from staging into the application folder
fileName = inbox.nextFile();
if (fileName) {
console.log(`Received File: <${fileName}>`);
let data = fs.readFileSync(fileName, "json");
statusText.innerText = `Received: ${data}`;
} while (fileName);
