Is there a way to set the simulator settings so that they are persistent every time you start the simulator?
Example. Can we set the heart rate at a certain level, and/or the battery level at a certain level, so that when the simulator is closed and restarted, it is started with some custom settings.
Unfortunately, not, but please submit a feature suggestion.
https://community.fitbit.com/t5/Feature-Suggestions/idb-p/features/label-name/sdk/tab/most-kudoed
