I needed a confirmation box for my application and then realized I also needed to create a short conversation with the user. Something along the lines of "Exit? Y/N? -> Save Data? Y/N/C . At this writing the SDK doesn't have a PopUp box like the Alert or Confirm in Javascript.
To fix this, I created a "module" for the FitBit to display a popup box. It's easy to use and easy to add to an existing application. It works fine on the Ionic and will probably work on the Versa but I have not tested it on that watch.
If you need this, you can pull source and instructions at: https://github.com/Skiddy69/Dialog
Rich
Example OK/Cancel Popup
Example Yes/No Popup
Example Yes/No/Cancel Popup
Very cool!
You might want to update it with some of the popup code here https://dev.fitbit.com/build/guides/user-interface/components/buttons/#popup-with-buttons
Please submit it to the open source directory https://github.com/Fitbit/ossapps
Best AnswerI have to admit I consider that a real compliment coming from you. Thanks.
I'm unsure what code you're referring to that I might want to update to? The only thing that I saw was to change the square button to square button positive and neutral. Which I did. My thinking was to keep the changes to the existing applications to a minimum including the import statements and style sheet changes. With that in mind I settled on the one import I needed for the two types of buttons and styling the objects inline. I am new to coding for the FitBit so any advice is appreciated.
It's not readily obvious to me how to submit to the open source directory. Do I start a "pull request"
Thanks.
Rich
