05-13-2018 16:33
05-13-2018 16:33
So far I have imported my steps into the watch face, but I notice that it only updates on my watch face when I swipe up to view the steps that the fitbit shows. How do I make this continually update?
let stepsLabel = document.getElementById("steps");
console.log((today.local.steps || 0) + " Steps");
stepsLabel.text = ((today.local.steps || 0) + " Steps");
Best Answer05-16-2018 21:43
05-16-2018 21:43
Thanks for your help. I actually just renamed today to "thisday" for the time portion of that code and that seemed to work.
let thisday = evt.date; let hours = thisday.getHours(); let sec = thisday.getSeconds();
and then used today for my steps, distance etc.
let stepsLabel = document.getElementById("stepsLabel");
05-13-2018 17:26
05-13-2018 17:26
Your code needs to keep updating by either calling through the on the clock tick probably a function called updateClock in this example:
clock.ontick = () => updateClock();
Or in a function that is called on an interval; like updateClockData in this example:
setInterval(updateClockData, .5*1000);
The advantage here is that my updateClock is only called once per minute, but updateClockData is called twice a second (which might be a bit aggressive; but I wanted a widget to move somewhat quickly on this face; namely a needle that shows your relative heart rate).
Best Answer05-13-2018 17:30
05-13-2018 17:30
Also if you use
today.adjusted.steps
instead of
today.local.steps
You will get the fitbit account value instead of just the value from your watch. This can fall out of sync if you have multiple devices.
Best Answer05-13-2018 20:59
05-13-2018 20:59
Thanks I created a separate function that now updates my steps every second, but this function is outside of my clock function, and that seems to have stopped my watch from reading time, do they need to be inside the same function?
clock.ontick = (evt) => {
let today = evt.date;
let hours = today.getHours();
let sec = today.getSeconds();
let year = today.getYear();
let monthnum = today.getMonth();
let day = today.getDate();
var month = new Array();
month[0] = "01";
month[1] = "02";
month[2] = "03";
month[3] = "04";
month[4] = "05";
month[5] = "06";
month[6] = "07";
month[7] = "08";
month[8] = "09";
month[9] = "10";
month[10] = "11";
month[11] = "12";
let monthname = month[monthnum];
if (preferences.clockDisplay === "12h") {
// 12h format
hours = hours % 12 || 12;
} else {
// 24h format
hours = util.zeroPad(hours);
let mins = util.zeroPad(today.getMinutes());
let sec = util.zeroPad(today.getSeconds());
//myLabel.text = (hours ":" (today.getMinutes()) ":" (today.getSeconds()) );
myLabel.text = `${hours}:${mins}:${sec}`;
myMonth.text = `${monthname}-${day}-${year}`;
myDay.text = `${day}`;
//myYear.text = `${year}`;
clock.ontick = function(updateSteps){
//steps
//floors
let stairsLabel = document.getElementById("stairs");
console.log(today.local.eleviationGain || 0);
stairsLabel.text = ((today.local.elevationGain || 0) + " Floors");
Best Answer05-14-2018 04:38
05-14-2018 04:38
You can only have 1 on onTick function. you can put the code from update steps directly into the updateClock or have the last step of updateClock be a call to updateSteps.
A clean/isolated approach I might suggest to one of my students would be something like this:
clock.ontick = () => doUpdates();
Then doUpdates:
function doUpdates(){
updateClock();
updateStats()
}Next updateClock:
upDateClock(){
let today = new Date();
let month = util.zeroPad(today.getMonth());
// 12h format
} else {
// 24h format
};finally updateStats:
function updateStats(){
//steps
//floors
Best Answer05-14-2018 19:36
05-14-2018 19:36
Thanks, I'm still having issues with nothing updating with this method.
updateClock();
updateStats();
// Clock
function updateClock(){
clock.granularity = "seconds";
let year = today.getYear()-100;
let weeknum = today;
var weekday = new Array();
weekday[0] = "Sun";
weekday[1] = "Mon";
weekday[2] = "Tues";
weekday[3] = "Wed";
weekday[4] = "Thur";
weekday[5] = "Fri";
weekday[6] = "Sat";
let weekname = weekday[weeknum];
month[0] = "01";
month[1] = "02";
month[2] = "03";
month[3] = "04";
month[4] = "05";
month[5] = "06";
month[6] = "07";
month[7] = "08";
month[8] = "09";
month[9] = "10";
month[10] = "11";
month[11] = "12";
// 12h format
} else {
// 24h format
myDay.text = `${weekname}`;
}Then I have this.
//steps
let mySteps = document.getElementById("mySteps");
mySteps.text = ((today.local.steps || 0) + " Steps");
//floors
let myStairs = document.getElementById("myStairs");
myStairs.text = ((today.local.elevationGain || 0) + " Floors");
// Battery
let batteryLabel = document.getElementById("battery");
console.log(Math.floor(battery.chargeLevel) + "%"); //retreive battery data
batteryLabel.text = ((battery.chargeLevel) + "%"); // send battery data to index.gui
};When I run the app nothing is updating on the console log...
Best Answer05-14-2018 19:40
05-14-2018 19:40
Not on my computer right now, but I want to say it is that the line:
Needs to be outside of any function. Otherwise it only gets set after the fun3is called... And it is never called since it is never set.
Best Answer05-14-2018 21:25
05-14-2018 21:25
I moved that line outside the function. Now it is telling me that "evt" is not defined.
I believe that this has something to do with the following line
Since the onclick function is now referring to
and "evt" is no longer initialized.
Best Answer05-15-2018 02:48 - edited 05-15-2018 02:49
To fix that I would change
To
Best Answer05-15-2018 04:01
05-15-2018 04:01
let today = evt.date; let hours = today.getHours(); let sec = today.getSeconds(); let year = today.getYear(); let monthnum = today.getMonth(); let day = today.getDate(); var month = new Array(); month[0] = "01"; month[1] = "02"; month[2] = "03"; month[3] = "04"; month[4] = "05"; month[5] = "06"; month[6] = "07"; month[7] = "08"; month[8] = "09"; month[9] = "10"; month[10] = "11"; month[11] = "12"; let monthname = month[monthnum]; if (preferences.clockDisplay === "12h") { // 12h format hours = hours % 12 || 12; } else { // 24h format hours = util.zeroPad(hours); } let mins = util.zeroPad(today.getMinutes()); let sec = util.zeroPad(today.getSeconds()); //myLabel.text = (hours ":" (today.getMinutes()) ":" (today.getSeconds()) ); myLabel.text = `${hours}:${mins}:${sec}`; myMonth.text = `${monthname}-${day}-${year}`; myDay.text = `${day}`;
let stepsLabel = document.getElementById("steps"); stepsLabel.text = ((today.local.steps || 0) + " Steps"); let stairsLabel = document.getElementById("stairs"); stairsLabel.text = ((today.local.elevationGain || 0) + " Floors");
Try it like this, you can use ontick only once, do everything in one ontick, update the date, the time and the stats 🙂
05-16-2018 21:43
05-29-2019 17:44
05-29-2019 17:44
what is the variable name for the steps
Best Answer05-31-2019 05:34 - edited 05-31-2019 05:36
Reference is my Really Basic clockface
import userActivity from "user-activity"; //adjusted types (matching the stats that you upload to fitbit.com, as opposed to local types)
let stepsValue = (userActivity.today.adjusted["steps"] || 0); // steps value measured from fitbit is assigned to the variable stepsValue
console.log("steps: " + stepsValue);
Best Answer09-22-2020 17:17
09-22-2020 17:17
Thank you, Dcable! I couldn't get this to work any other way, either!
I was able to keep it a bit simpler with the line:
mySteps.text = today.adjusted.steps;
But the "today" wasn't working until I changed it to:
For some reason you couldn't reuse the "today" in both instances.
New code for me:
let hours = hours % 12 || 12;
let mins = zeroPad(thisday.getMinutes());
myLabel.text = `${hours}:${mins}`;
myBat.text = battery.chargeLevel + "%";
//convert date to string and slice from left start 0 to 10 characters
myDate.text = thisday.toString().slice(0, 10);
heartSensor.start();
