09-24-2020 14:59
09-24-2020 14:59
I am trying to create a simple watch face but every time I do this error comes up saying "One or more required files do not exist in the project: resources/index.gui and resources/widgets.gui". I have tried just adding the files but when I add them they are blank and make the clockface black. Does anyone know what code I have to put in the files? I am trying to run to work with the 4.2 OS and the Versa 2. Thanks!
09-25-2020 02:43
09-25-2020 02:43
It sounds like you made a new project whilst SDK 5.0 was being deployed.
Rename /resources/index.view to /resources/index.gui
Rename /resources/widget.defs to /resources/widgets.gui
Edit /resources/widgets.gui and replace the contents with this:
<svg>
<defs>
<link rel="stylesheet" href="styles.css" />
<link rel="import" href="/mnt/sysassets/widgets_common.gui" />
</defs>
</svg>
10-14-2020 11:54
10-14-2020 11:54
Same issue still existed for me (2020-10-14). The solution below helped.
I also use 4.2OS and a Versa - no Lite, no 2, no 3 - just Versa 😉
Thanks for posting the original question and the solution 🙂
Best Answer01-14-2021 15:06
01-14-2021 15:06
I get this issue
Hi all I'm trying to run the sample from get started, a clock face. I get connected to the simulator and stuff though I get the following errors. And I don't see anything that talks about them is the get started.
This project is being built without a companion component. Create a file named companion/index.ts or companion/index.js to add a companion component to your project.
Resources set as: Fitbit Versa SDK 4.2
Any help
Best Answer01-14-2021 15:21
01-14-2021 15:21
Corrected
Best Answer02-14-2021 19:20
02-14-2021 19:20
This recommended fixes have been useful in getting Ionic simulator to work properly.
