I've seen a couple of posts from a few months ago asking if there was a way to get the 250 steps/hour value. Is that still not available in the device API, and would the only way to get access to it to register a web app and get the intraday data from the web api?
What I'm basically trying to do is replicate my old Charge HR2's readings onto a single watch face for my Versa (HR, total steps, calories, floors, active minutes, and steps for the current hour). That is the last piece I'm missing.
Best AnswerA somewhat safer solution is to use activity history. That way, you'll still get pretty good results even if your clockface wasn't running at the start of the hour (eg, because the user was using an app such as Exercise or Settings). For best results, you need to add the steps since the last minute, but even if you don't do that, you'll get close.
