Is there a way to set custom url parameters for the oauth url in the settings?
For google oauth i need :
access_type=offline
<Oauth
settingsKey="oauth" title="OAuth Login" label="OAuth" status="Login" authorizeUrl="https://accounts.google.com/o/oauth2/v2/auth" requestTokenUrl="https://www.googleapis.com/oauth2/v4/token" clientId="11111" clientSecret="asdfxxx" scope="profile" customParameter=myvalue />
<Oauth
settingsKey="oauth"
title="Google Authentication"
label="Approve Access to Google"
status={getDisplayWebAPIStatus(props)}
authorizeUrl={CREDENTIALS.google_authorisation_url}
requestTokenUrl={CREDENTIALS.google_access_token_url}
clientId={CREDENTIALS.client_id}
clientSecret={CREDENTIALS.client_secret}
scope={CREDENTIALS.scope}
pkce="true"
oAuthParams={{
access_type : 'offline',
prompt : 'consent'}}
Is there a way to get a Google Oauth refresh token? Im stuck, i only get the auth token with the settings login...
Google needs to request a access_type which is set to offline. where can i set this in the settings?
https://developers.google.com/identity/protocols/OAuth2WebServer
Best Answeris there a way to set custom url parameters for the oauth url? For the google oauth i need :
access_type=offline
<Oauth
<Oauth
settingsKey="oauth"
pkce="true"
oAuthParams={{
