Is anyone seeing this issue? In the last week I have had customers reach out saying they enter data into my app settings, it transfers to the watch but after some time the data disappears on the watch. Almost as if something is deleting the resident file.
I am am left wondering what has changed? My app hasn't. I am not able to duplicate it in tests but I am running Android, so could it be an iOS 13/Fitbit OS 4.0 issue?
Best AnswerNot a dumb question, but yes all the data is bidding written to a file on the watch which the app then pulls the data from. It's been working fine for at least six eight months. but then last week I get seven or eight people that say the enter data into their app it goes to the watch and then disappears. Almost as if there's a communication issue writing to the file or the file is being deleted.
Best AnswerI had a similar issue. My problem was the file was being written before it was read occasionally.
The problem became more prevalent as the app got bigger. I found it by logging file actions to the console and they showed the write was triggering before the initial read was completed.
I addressed this by setting a first pass variable to true at the beginning of the module,
import {debug, lg} from "../../common/common.js"
import * as fs from "fs";
import {locale} from "user-settings";
import {gettext} from "i18n"
var fPass=true
then set it to false as part of the file read
fPass=false
const listDir = fs.listDirSync(".")
var dirIter
while((dirIter = listDir.next()) && !dirIter.done) {
let fileName = dirIter.value
switch (fileName){
case "kpay.status.cbor":
case "kps": break
case "p.txt":
e.update(fs.readFileSync(fileName, "cbor"),false)
break
default:
Then I check fPass before allowing the first write
,update:function(vals,saveSet=true){
if (Object.keys(vals).length!==0 && !fPass){
for (let val in vals){
if (typeof p[val] == typeof vals[val]) p[val] = vals[val]
else lg("pVar not Found",val,function(T){console.log(T)})
if (saveSet){
clearTimeout( pSvTO )
pSvTO = setTimeout(function(){fs.writeFileSync("p.txt", p, "cbor")}, 2000)
The timeout function is to facilitate consolidating multiple data updates into a single file transaction.
Regards,
Reign
This is from the watchface at https://gallery.fitbit.com/details/bda6f514-3946-49ba-a4ed-75e8470ab034
