Detecting 12/24 hour clock setting
ANSWERED
How do we detect whether the Ionic has been set to 12 or 24 hour display mode?
Will need this for digital clock faces.
1 BEST ANSWER
Accepted Solutions
import { preferences } from "user-settings";
console.log(preferences.clockDisplay);
(edited)
15 REPLIES 15
I have found the User-settings API in the reference documentation.
So, would I access it with something like this:
  import (UserSettings) from "User-settings";
  var settings = new UserSettings();
  if (settings.clockDisplay === "12h") .....
(edited)
@JonFitbit wrote:
import { Preferences } from "user-settings";
console.log(Preferences.clockDisplay);
preferences needs to be lowercase.
I hate to be "that guy"; but copying your sample caused a bit of frustration as it would fail to load clockdisplay from undefined.
Thanks, I've fixed my reply
I'm sorry; I'm not familiar with writing code.  I just used the help instructions fitbit provided in order to make my own clock face.  This (below) is the index code.  Where do I put the code you provided in order to change my time from 24-hour to 12-hour?  I'm sorry; I imagine this is a dumb question but I just can't figure it out.
import clock from "clock";
import document from "document";
import * as util from "../common/utils";
// Update the clock every minute
clock.granularity = "minutes";
// Get a handle on the <text> element
let myLabel = document.getElementById("myLabel");
// Update the <text> element with the current time
function updateClock() {
let today = new Date();
let hours = today.getHours();
let mins = util.zeroPad(today.getMinutes());
myLabel.text = `${hours}:${mins}`;
// Update the clock every tick event
clock.ontick = () => updateClock();
Try this:
if (preferences.clockDisplay === "12h") {
hours = (hours + 24) % 12 || 12;
Ah!  Thank you so much!  That did it!  You are awesome!  There is absolutely no way I would ever have figured out how to customize my watch face without you.  I really appreciate your help.
Thanks! If you're on Twitter, you should share your creation with the world. #made4fitbit
Thanks! I also prefer the 12 hour time and the solution worked for me. However, the clock face doesn't show am or pm after the time. Is there a way to add that?
Here is how I do it:
let ampm = " am"
if (preferences.clockDisplay == "12h"){
if (hours > 12){ ampm = " pm"; hours -= 12; } else if (hours == 12){ ampm = " pm" } else if (hours == 0 && ampm == " am"){ hours += 12; } } else { ampm = "" } clockLabel.text = `${hours}:${mins}${ampm}`;
Worked perfectly! Thanks so much.
How can I add 12h clock?
clock.granularity = "seconds"; // seconds, minutes, hours
clock.ontick = function(evt) {
  // Output the date object
  console.log(evt.date.toString());
import * as simpleActivity from "./simple/activity";
import * as simpleClock from "./simple/clock";
import * as simpleHRM from "./simple/hrm";
let txtDate = document.getElementById("txtDate");
let txtHRM = document.getElementById("txtHRM");
let iconHRM = document.getElementById("iconHRM");
let imgHRM = iconHRM.getElementById("icon");
let statsCycle = document.getElementById("stats-cycle");
let statsCycleItems = statsCycle.getElementsByClassName("cycle-item");
function clockCallback(data) {
  txtDate.text = data.date;
simpleClock.initialize("minutes", "longDate", clockCallback);
function activityCallback(data) {
  statsCycleItems.forEach((item, index) => {
    let img = item.firstChild;
    let txt = img.nextSibling;
    txt.text = data[Object.keys(data)[index]].pretty;
    // Reposition the activity icon to the left of the variable length text
    img.x = txt.getBBox().x - txt.parent.getBBox().x - img.width - 7;
simpleActivity.initialize("seconds", activityCallback);
function hrmCallback(data) {
  txtHRM.text = `${data.bpm}`;
  if (data.zone === "out-of-range") {
    imgHRM.href = "images/heart_open.png";
  } else {
    imgHRM.href = "images/heart_solid.png";
  if (data.bpm !== "--") {
    iconHRM.animate("highlight");
simpleHRM.initialize(hrmCallback);
const myLabel = document.getElementById("myLabel");
// Update the <text> element every tick with the current time
clock.ontick = (evt) => {
  let today = evt.date;
    // 12h format
    hours = hours % 12 || 12;
  } else {
    // 24h format
    hours = util.zeroPad(hours);
let myClock = document.getElementById("myClock");
clock.granularity = 'seconds'; // seconds, minutes, hours
  myClock.text = ("0" + evt.date.getHours()).slice(-2) + ":" +
                      ("0" + evt.date.getMinutes()).slice(-2) + ":" +
                      ("0" + evt.date.getSeconds()).slice(-2);
i dont really know where to ask this so i ll just relpy here. im having a hard time figuring out how to make a versa detect 12 hour clock vs 24 hour clock, it seem to be stuck on 24. I just dont know what im doing to be honest. this is what i have in the index page.
import { HeartRateSensor } from "heart-rate";
import { today } from "user-activity";
let date = document.getElementById("date");
let time = document.getElementById("time");
let hBpm = document.getElementById("heartRate");
var hrm = new HeartRateSensor();
hrm.onreading = function(){
//hBpm.text = hrm.heartRate + " BPM";
//console.log("Current heart rate: " + hrm.heartRate);
hrm.start();
date.text = util.getDateString(today);
time.text = util.getTimeString(today);
The question has already been answered above (clockDisplay). Your getTimeString() function needs to take this into account.
Peter McLennan
Gondwana Software
This is the way I find it efficient. Put this into your index.js:
AMPM.text = today.getHours() < 12 ? "AM" : "PM";}
If this answer works please mark this post as a Best Answer.  ~ K.K Designs
