09-25-2020 10:28
09-25-2020 10:28
If you're developing using a Fitbit Versa 3 or a Fitbit Sense and you're experiencing a reboot when using the developer bridge, complete this form for access to a beta firmware.
It's only for Versa 3 and Sense, and doesn't include anything else, so only complete the form if you need it. https://forms.gle/j7fzYb9evrtCxs879
Best Answer09-30-2020 00:09 - edited 09-30-2020 00:19
I don't experience any reboots, but my Versa 3 will not connect to the Developer Bridge. It seems to time out and give up after about a minute of circling around the toggle switch. I am logged in to the developer environment through the CLI. The Fitbit Simulator connects fine. Any ideas what could be the cause?
Thanks
Jon from Denmark
Best Answer09-30-2020 01:39
09-30-2020 01:39
It's actually connected, but the Settings app isn't showing it. Just try connecting from the CLI. `connect device`.
If you register for the beta firmware, you can update the Settings app to fix this issue.
10-01-2020 02:19 - edited 10-01-2020 04:12
So it works as long as you don't have the Sense connected to the charger. If you connect it to a charger, after a few seconds without fail it'll crash and restart the device.
Edit: Actually to narrow it down it seems to be whenever it's taken off a wrist or at least would ask for the password again.
10-02-2020 07:27
10-02-2020 07:27
Thanks Jon, that worked 🙂
Best Answer10-07-2020 23:37
10-07-2020 23:37
Hello Jon,
I am under firmware 44.128.2.35 on my sense and the developer bridge now works fine without crashing my sense.
However, I cannot access the ECG application. Is there a way to have the ECG in this firmware version, or a way to revert back?
Regards
10-10-2020 21:50 - edited 10-10-2020 21:51
I can confirm the same behaviour with the ecg app. It's asking us to make sure we are on the latest update
Best Answer11-26-2020 06:11
11-26-2020 06:11
I updated to Fitbit OS 5.1 (128.4.15) on Fitbit Versa 3. This crash seemed to fix it.
