01-08-2020 02:13
01-08-2020 02:13
Hi all,
I'm trying to built my first app but I don't understand which is Developer Id, and without this a can't run my app. I'm doing something wrong?
You can help me, please?
Thanks!!
Best Answer01-10-2020 02:39
01-10-2020 02:39
Can you explain more about your issue? What's asking for a developer ID?
Best Answer01-13-2020 07:41
01-13-2020 07:41
I made a new project "digital clock" and when I tried to transform it in a app I have to insert Developer ID in package.josn section, but I don't understand what it is.
Here the section that I talked about.
Thanks!!
Best Answer01-13-2020 11:58
01-13-2020 11:58
If you open the project's page in the Fitbit Gallery App Manager, you should see your developer ID given near the top.
01-14-2020 10:39
01-14-2020 10:39
You should only need to enter those IDs if you're using App Cluster Storage.
Best Answer08-02-2021 09:51
08-02-2021 09:51
I still can't find developer and cluster ID for my Fitbit ionic I need help
Best Answer08-02-2021 13:31
08-02-2021 13:31
Developer ID is given on GAM page for a project.
You can make up your own cluster ID. See https://dev.fitbit.com/build/reference/companion-api/app-cluster-storage/
