Development Basics
ANSWERED
1) I have created 'text' from index.gui, it s possible to create 'text' only in js file?
2.a) texts position can be set from styles.css or index.gui both in pixel and percentages. In js files, how to set the position in percentages?
2.b) Or how to get the screen dimension in pixels from a js file?
3) There is no completion in the js editor?
4) How integrate configuration managment, GIT...?
Thank you
1 BEST ANSWER
Accepted Solutions
1. No.
2a. Percentages can only be specified in .gui.
2b. https://dev.fitbit.com/build/reference/device-api/device/
3. There is if you use CLI and a good editor.
Peter McLennan
Gondwana Software
2 REPLIES 2
Ok for 4) (GIT) the answer was in command line section.
https://dev.fitbit.com/build/guides/command-line-interface/
1. No.
Peter McLennan
Gondwana Software
