Hi, I have a question, if I develop a app, can I intall the app in anything fitbit devide ?
@Yahuarcani wrote:Hi, I have a question, if I develop a app, can I intall the app in anything fitbit devide ?
If you develop an app, it can generally be used on Versa 2, Ionic, Versa and Versa light.
There are some differences though. For example: Versa light doesn't have elevation sensors, Versa 2 doesn't have on watch GPS, and Ionic has different screen dimensions than the Versa models
Also Versa 2 has more memory available than the other models, and some idiosyncrasies with it's rendering.
I usually develop mostly with the simulator using Versa 1 as a device type, occasionally simulating an Ionic for the screen dimension differences, and eventually with a physical Versa 2 to make sure it actually works. And, I do build to all available models no matter what the target is.
thanks, it means I couldn't prove my app in a fitbit inspire HR ?
