I want to display a notification like the notifications you get when you get a message or an email.
(A notification on the Versa 3)
How do I do this?
Thanks,
Techninja
The Fitbit API doesn't provide for this. You could do it by getting some other app on the phone to display the notification. You may need to write a native app for the phone to do this. Getting your fitbit code to communicate with it would be difficult but possible.
Best AnswerThe Fitbit API doesn't provide for this. You could do it by getting some other app on the phone to display the notification. You may need to write a native app for the phone to do this. Getting your fitbit code to communicate with it would be difficult but possible.
Best AnswerOk. Thanks for the answer!
Have a look at Macrodroid for the phone - it can produce notifications based on all sorts of different triggers
