Looking for the most optimized way to display additive list selections. Below is the code for my sample list.
<AdditiveList
title="Select List"
settingsKey="list"
maxItems="5"
renderItem={
({ name, value }) =>
<TextImageRow
label={name}
sublabel={value.location}
addAction={
<Select
label="Add Item"
options={[
{ name: 'Label1', required: false, value: {location: 'Sub-Label'} },
{ name: 'Label2', required: false value: {location: 'Sub-Label'} },
{ name: 'Label3', required: true, value: {location: 'Sub-Label'} },
{ name: 'Label4', required: false value: {location: 'Sub-Label'} },
{ name: 'Label5', required: false, value: {location: 'Sub-Label'} }
It displays properly in the app settings and I select Label, Label3 and Label5.
I am then parsing the JSON data to extract the values
if (evt.data.key === "list" && evt.data.newValue) {
let mSelect = evt.data.newValue.replace(/\\/g, "");
let mFinal = JSON.parse(mSelect);
From here I can console log the individual values without issue.
console.log(mFinal[0].value.location);
console.log(mFinal[1].value.location);
console.log(mFinal[2].value.location);
What I want to do from here is display each value in a list on the GUI with each one on its own line regardless of which one is selected.
If I set it as an ID text element, then I have to define the x and y coordinates which means there would be white space where one is not selected.
Any help is appreciated.
Best AnswerI was able to do this with the following if/else statements for each item:
if (mFinal[0] == null) {
let mselection1 = "None Defined";
else if (mFinal[0].value.location != null) {
let mselection1 = (mFinal[0].value.location);
