Documentation for VibrationPatternName
ANSWERED
I see that VibrationPatternName is documented here
https://dev.fitbit.com/build/reference/device-api/haptics/#vibrationpatternname
but how to access it?
I tried using the repl to search for it... no luck
fitbit$ repl$ var haptics = require('haptics')
fitbit$ repl$ for (x in haptics) console.log(x)
fitbit$ repl$ for (x in haptics.vibration) console.log(x)
Thanks!
1 BEST ANSWER
Accepted Solutions
You have to have your own array of the names, as per the app that you linked.
5 REPLIES 5
Try:
import { vibration } from "haptics";
vibration.start("ring");
From the documentation:
Rich
The question is about the VibrationPatternName variable/constant.
It's just a list of possible vibration pattern names.
        | "alert"
        | "bump"
        | "confirmation"
        | "confirmation-max"
        | "nudge"
        | "nudge-max"
        | "ping"
        | "ring"
But how I can read that list from my app?
How can I use it in the app?
I would like to use that list in an app, so that I can dynamically create the list of available patters... for example in this app https://github.com/adiroiban/fitbit-os-haptics
Thanks!
