08-24-2018
15:42
10:45
LanuzaFitbit
08-24-2018
15:42
10:45
LanuzaFitbit
I'm writing an internal app that caches some data offline and generally relies on a REST api for most functions.
The official docs state that storage behaves as a key store so my assumption based on my experience with key stores is that it should update whenever I call storage.set().
Unfortunately, my data does not update and now I'm wondering if there's something I missed. Do I have to manually remove and re-set a key to update it?
Ps: I'm using Ionic 3.9.2 and the official Ionic storage plugin.
my issue has been solved by reddit thankyou guys!
Moderator edit: Removed links
Best Answer08-25-2018 11:22
08-25-2018 11:22
@shrutigomes wrote:I'm writing an internal app that caches some data offline and generally relies on a REST api for most functions.Tutuapp
Unfortunately, my data does not update and now I'm wondering if there's something I missed. Do I have to manually remove and re-set a key to update it? 9apps
any update guys!!!
