Hello,
I use the code
positionTrenner = utf8_read.search(TRENNZEICHEN);
with positionTrenner is an integer, utf8_read is a (notempty) string and TRENNZEICHEN (=";") is a constant, which is part of utf8_read.
When I deactivate this line and use a fixed number for positionTrenner my code works fine, if I use this line of code my app cancels after a couple of seconds (but not exactly when this line is executed!). Same effect happens when I use a fixed string for example ";" instead of TRENNZEICHEN.
When the app is canceled in the console the message "App started" is printed,
Did anybody observe similar behavior?
Capitano
