Hi, me too. This came about in the transition from SDK 4.2 to 4.3.
The generated code is different [for the same program] than before and no longer fits in memory, simply rebuilding an app that worked in 4.2 won't even load with 4.3, though the original [4.2] app is running fine.
Even removing some of the original code didn't help make it fit memory.
You may have to give up supporting older watches [pre Versa 2].
Most annoying.
