Hello all,
I am trying to build my settings page so the user can change a variable within the app. I first used a slider and the slider label would update as the user slide their finger across. However, I have realized the slider is WAY too clunky on the phone.
Now I am trying to swap the design to use an increment button and a decrement button with a label in between to show the current value. The increment and decrement code is working, however the label is not being updated.
Also, will I be able to read this value in the companion?
Any ideas?
Thanks
Slider code
<Slider
label= {props.settings.flowTimeSlider.substring(1,props.settings.flowTimeSlider.length-1)}
settingsKey="flowTimeSlider"
min="0"
max="240"
Button Code
<Button label="+" onClick={()=> props.settings.flowTimeSlider++ }/>
<Text align="center">{props.settings.flowTimeSlider}</Text>
<Button label="-" onClick={()=> props.settings.flowTimeSlider-- }/>
After experimenting a while I ended up figuring this out myself.
According to the docs you can manage Settings Key yourself using the following code
onChange={value => this.props.settingsStorage.setItem('color', value)}
so I adapted that to my needs. One problem I ran into was casting between ints and strings, so it may not be the prettiest, but it does work.
<Button label="+" onClick={()=> {
props.settings.flowTime = parseInt(props.settings.flowTime) + 1;
props.settingsStorage.setItem('flowTime', props.settings.flowTime.toString())
<Text align="center">{props.settings.flowTime}</Text>
<Button label="-" onClick={()=> {
props.settings.flowTime = parseInt(props.settings.flowTime) - 1;
Best AnswerAfter experimenting a while I ended up figuring this out myself.
