Hello! Still new to the Fitbit SDK, and there is one thing that I can't get my head around.
My scenario:
I'm retrieving lunch menu data from an API. I get text responses with dynamic text length back. My lunch menu view file looks like this for a single day:
<use id="monday" href="#view-header">
<set href="text" attributeName="text-buffer" to="Monday"/>
</use>
<use href="#scrollview-item" display="flexible-height">
<use id="monday-slot-1" href="#dynamic-textarea" fill="white">
<set href="#text" attributeName="text-buffer" to=""/>
<!-- Allow 256 characters in lunch menu -->
<set href="#text" attributeName="text-length" to="256"/>
</use>
</use>
<use id="monday-slot-2" href="#dynamic-textarea" fill="white">
</use>
</use>The #view-header mimics the example from here.
I thought this would make the textboxes adjust to their content height when filled out with text from JavaScript, but I guess Fitbit's implementation is even more barebones than that. What I get is a view that doesn't scroll all the way to the bottom.
Any pointers to how I can dynamically do this adjustment? It should sure be possible... right?
Best AnswerI don't have experience with the scrollview widget, but off the bat are you making sure to use these inside of
<use href="#scrollview">
However I may not be understanding the nature of the problem. If this doesn't help, perhaps you can provide a screenshot as an example of what you're seeing?
Best AnswerYeah, I made sure to use it inside a scrollview.
Trying to populate the first three slots with this text:
[18:18:35] App: Filled out monday-slot-1 with text Flygande Jacob, (kycklinggratäng med ris, chiligräddsås, banan serveras med bacon & jordnötter vid sidan av) (app/index.js:111,17)
[18:18:35] App: Filled out monday-slot-2 with text Räkgryta Indienne med ris, en favorit i repris (app/index.js:111,17)
[18:18:35] App: Filled out monday-slot-3 with text Tandoorigryta med grönsaker, serveras med ris och mango chutney
Gives me the following result: see video: https://files.catbox.moe/735he9.mov
The full page code is:
<svg>
<animate attributeName="x" from="100%" to="0" begin="load" dur="0.5" easing="ease-in-out" />
<!-- Lunch menu -->
<svg id="lunchMenu" pointer-events="all">
<use href="#scrollview" id="#main-scrolling">
<set href="text" attributeName="text-buffer" to="Måndag"/>
</use>
</use>
</use>
</use>
</use>
<use id="monday-slot-3" href="#dynamic-textarea" fill="white">
</use>
</use>
<use id="monday-slot-4" href="#dynamic-textarea" fill="white">
</use>
</use>
<use id="monday-slot-5" href="#dynamic-textarea" fill="white">
</use>
</use>
</use>
</svg>
</svg>
