06-27-2018 13:55
06-27-2018 13:55
<svg>
<use id="container" href="#panoramaview">
<use href="#panoramaview-item">
<svg class="page">
<use id="stats-cycle" href="#cycleview">
<use href="#cycleview-item" class="cycle-item">
<text>Steps: 1,337</text>
</use>
</use>
</svg>
</use>
<svg class="page">
<rect id="background2" />
<text id="debug">Sup...</text>
</svg>
</use> <!-- PAGE2 -->
</use>
</svg>
06-28-2018 00:03 - edited 06-28-2018 00:04
Do you have any error messages when you build or when you run it? If not, I would try removing the inner svg's and check if you have all the imports for panoramaview and cycleview. If that works you can start from there.
Something like this for your gui file:
<svg>
<use id="panitem1" href="#panoramaview-item">
<use id="cycleitem1" href="#cycleview-item" class="cycle-item">
</use>
<use id="cycleitem2" href="#cycleview-item" class="cycle-item">
<text>Cycle 2</text>
</use>
</use>
</use>
<use id="panitem2" href="#panoramaview-item">
</use>
</svg>(I added id's to every cycle item and pan item for clarification, I don't know if they need one to work)
Your imports (widgets.gui) need to contain
<svg viewport-fill="fb-green">
<defs>
<link rel="stylesheet" href="styles.css" />
<link rel="import" href="/mnt/sysassets/widgets_common.gui" />
<!-- Additional Imports -->
<link rel="import" href="/mnt/sysassets/widgets/baseview_widget.gui" />
<link rel="import" href="/mnt/sysassets/widgets/cycleview_widget.gui" />
<link rel="import" href="/mnt/sysassets/widgets/panoramaview_widget.gui" />
<link rel="import" href="/mnt/sysassets/widgets/pagination_dots.gui" />
</defs>
</svg>
(I haven't put this in a project to test out so sorry if there are any syntax errors)
Best Answer06-28-2018 11:20
06-28-2018 11:20
All my widget imports are correct. I get no errors logged on build or run.
I have tried your sample it does not log any errors but also does not work.
It displays page 2 by default and does not respond to swipe gestures to change page.
08-09-2019 06:56
08-09-2019 06:56
I have a similar issue, just the other way around. Is there any fix for this?
