12-27-2019 16:16
12-27-2019 16:16
Hello,
I have a simple cycleview component that displays either calores and heartrate or steps and battery level. The component works as expected, but i want to add a touch event so that the watch vibrates when the cycleview component is activated. I defined a button inside the clycleview SVG to trigger the vibration but can't get it to work. Here's the SVG with the button definition in bold:
<svg x="0" y="81%" width="100%" height = "20%" >
<rect id="Touch" width="100%" height = "100%" fill="none" pointer-events="visible" />
<use id="stats-cycle" href="#cycleview">
<use href="#cycleview-item" >
<image href="stat_cals_solid_48px.png" height="48" width="48" x="0" y="0" fill="orange"/>
<text id="cal"></text>
<image href="stat_hr_solid_48px.png" height="48" width="48" x="200" y="0" fill="red" />
<text id="cor"></text>
</use>
<image href="stat_steps_solid_48px.png" height="48" width="48" x="0" y="0" fill="yellow"/>
<text id="pas"></text>
<image id="batImg" x="200" y="7" height="32" width="21"/>
<text id="bat"></text>
</use>
</use>
</svg>
The index.js has the function definition:
let Touch = document.getElementById("Touch");
Touch.onmousemove = function(evt) {
console.log("Touch event: " + evt.screenX + ' ' + evt.screenY);
vibration.start("confirmation-max");
I don't get any error messages during compilation. Any suggestions?
Best Answer12-28-2019 15:36
12-28-2019 15:36
Actually I figured it out - it's as easy as emaking the pointer-events "visible" for the cycleview component itself, no need to define an additional button. Also, use 'onclick' instead of 'onmousemove' in the .js file. The SVG solution looks like this:
<use id="stats-cycle" href="#cycleview" pointer-events = "visible">
</use>
<image href="stat_steps_solid_48px.png" height="48" width="48" x="0" y="0" fill="skyblue"/>
<image id="batImg" x="210" y="7" height="32" width="21"/>
</use>
</use>
</svg>
This is the java-script:
let click = document.getElementById("stats-cycle");
click.onclick = function(e) {
console.log("Touch event!!");
vibration.start("bump");
