06-18-2018 14:28
06-18-2018 14:28
Hello,
I thought this was covered somewhere, but I can't find it.
I am trying to incorporate the image picker into my clock face. When I run it, I get:
companion-runtime:/bootstrap.js:1,1090[5:21:19 PM]Uncaught non-error: RangeError: Encoded data too large: 152436 bytes
in the console log. The picture does not appear to complete the transfer and load. Everything else works. How do I get the image to move without over-sizing? I seem to remember reading about this somewhere, but I can't find it now.
Thanks.
Best Answer06-18-2018 20:02
06-18-2018 20:02
Use file transfer rather than messaging, if you're not already.
Send a JPG, compressed as need be.
Ensure image size is set in companion/settings to match what you need on the watch.
Best Answer06-20-2018 18:07
06-20-2018 18:07
Thank you for the feedback. I am already trying to do that. The problem seems to be occurring when I try and combine the send file (like in the fitbit example of sending an image) and sending a standard setting (like a font color). Is there a trick or limitation in combining the two?
Thanks again.
